  #1
Old May 17th, 2002, 06:08 PM
gprestridge gprestridge is offline
Default 20 hp Mariner running bad
I have a 20 hp mariner-about 90 model--runs good at wide open speed but dies atlower speed-after some running new plug inspection showed one plug looked almost asif it hadn't been used-only slight gray/smoke color in one small spot-rest of plug still looked brand new--any thoughts
  #2
Old May 17th, 2002, 06:44 PM
12Footer's Avatar
12Footer 12Footer is offline
Default Re: 20 hp Mariner running bad
Welcome to iboats,Gp.If water gets into the cylinder, the heat will make steam, and steam clean the plug. I would check the compression before doing anything else.Of course, water can also get into it from the gas tank,so check that too.
__________________
"Did you hear about the guy whose whole left side was cut off? He's all
right now."
  #3
Old May 17th, 2002, 08:56 PM
hondon hondon is offline
You don't say which plug looked however.Is this engine new to you?By all means do the comp. check as suggested and take a little fuel sample to check that possibility.There are alot of conceivables here so more info might help.
  #4
Old May 18th, 2002, 10:12 AM
It was the bottom cylinder that looked as if the plug had never been fired except for one very small spot-the rest of the ring looked brand new--Actually this motor belongs to my Dad-he is very peculiar about clean gas etc..he assures me it has no water in it-I had some info wrong also--he fishes the Mississippi River and a day or so ago it ran up the river 20 minutes wide open fine then just suddenly shut down--like to have never cranked but finally did--ran lines running fair-then later almost ran battery down trying to crank it-got it cranked and ran 20 minutes or so wide open down the river-seems asif something might be heating up and shutting down-I told him to replace the plug which appears different and I also told him to check to be sure his tank line is not cracked or leaking at a fitting.any other suggestions appreciated..
  #5
Old May 18th, 2002, 01:25 PM
Now I know a little more-I went and tinkered with it some..Compression on bottom cylinder is 140 and top is 120--did finally getit cranked and it ran reasonably well (for a Mariner)killed it and it would hit but didn't want to run-kept trying and finally cranked again-many times when I hit the starter it would not turn over(like it was vapor locked or something)-I removed the bottom plug and it would turn over free-I replaced the bottom plug and removed the top plug and it would be "vapor locked" again-something going on with bottom cylinder-I'm just not sure what it is..fire looks strong..
  #6
Old May 21st, 2002, 03:42 PM
Somebody mentioned possibly a leaking exhaust gasket-they recommended replacing the two gaskets-facing the front of the motor,where are these gaskets.Easy to do??If same person sees this post please reply to gprestridge@netdoor.com--I've had computer problems and may have llost your previous reply.Thanks
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
93 MAGNUM 40 MARINER ...RUNNING HOT RICKYC53 Mercury & Mariner Outboards 16 January 13th, 2007 10:53 PM
Mariner 150 still running HOT. rocks Mercury & Mariner Outboards 8 July 10th, 2005 05:54 AM
94, 40 Mariner not starting after running OK JQF Mercury & Mariner Outboards 0 May 13th, 2004 07:44 AM
'95 Mariner 60--running on 2/3 Dman Mercury & Mariner Outboards 2 April 16th, 2004 05:34 AM
82 mariner 90 hp running weird jamescody Mercury & Mariner Outboards 8 August 14th, 2002 09:28 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
