I have a 115 merc and the front tank was removed for corrosion reasons before I even got the boat. There was a 5 gallon tank in the back so I bought another 5 gallon tank and mounted both in the bow. Now after priming the bulb my motor runs fine until the fuel in the line runs out then stalls, re-prime the bulb and same thing. If I remove the line and put the tank in the back again I have no problems at all.<br />Any idea's as to what could be causing this?<br />Thanks, <br />Falker
