  #1
Old May 10th, 2002, 04:40 AM
dlittle dlittle is offline
Default Mercury 25 HP overheated after dealer service
Mercury 25HP, 1985 electric start running fine except for a bit rough and occasional miss at idle, taken to dealer for routine service. Dealer advised electronic module down as reason for rough idle, also replaced impellor. Compression on both cylinders reported as good at 130. Boat used at slow speeds for two days then stopped pumping water and got hot (steam at tell tale) but did not seize. Took back to dealer who now says that gasket on side plate failed and exhaust gas pressure prevented water from flowing around head as reason for overheat. Has now planed side plate so that it seats, replaced head gasket and says now OK but I should now trade up to new motor. I don't know much about motors, does this all sound legitimate. If not, any ideas on cause of overheat so soon after service.Thanks....Optimistic
  #2
Old May 10th, 2002, 04:45 AM
FlyBoyMark FlyBoyMark is offline
Ensign
Default Re: Mercury 25 HP overheated after dealer service
Do a compression check again.....If you use the engine alot in salt water this is nothing unusual. Sounds like you stopped the engine before any damage....make sure you flush it after using in salt water......
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
mecury 90hp sport jet dealer service bullitins mark.aa Mercury & Mariner Outboards 1 February 4th, 2005 12:36 AM
mercury 225 efi overheated ? bandit01 Mercury & Mariner Outboards 5 October 22nd, 2004 06:16 PM
mercury 115 inline overheated siezed Rienel Mercury & Mariner Outboards 0 July 1st, 2003 10:52 AM
Mercury overheated is it cooked? 7-up Mercury & Mariner Outboards 2 June 18th, 2003 03:27 AM
Mercury XR 150 - Piston Overheated Terry421 Mercury & Mariner Outboards 2 January 24th, 2003 02:18 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
