This is a petty lengthy discription of the problem I am having with my motor. When I first start it up in the morning it idles rough and idles rough all the way out of the cove that I launch from (approx 1 mile). After I get out of the NO WAKE zone I push down on the throttle and I hardly get anything for acceleration. It may run this way for about 5-10 minutes and then suddenly it will kick in ,plane out, and run great for the rest of the day. Eve if I turn it off it will run great. It is not a build up of RPMs and power but more like it just decides to kick in. My gas is clean.....my fuel filter is clean.......my plugs are good.......I have a maintenance manual for this motor but I can find nothing that addresses this specific problem. <br />I'm gonna relate some other things that are occuring that may or may not be related to this problem: <br />1. When I pump up the fuel bulb it will pump the gas into the motor and slowly get harder to pump but it never gets <br />so hard that it cannot be squeezed a little with a good amount of pressure <br />2. If I am running to a fishing area for approx 20-30 minutes it may never "kick in" but when I start it to leave it <br />might "kick in" on start-up and then run right all day. <br />3. I have been dealing with this for a while.......it seemed like it took longer for it to "kick in" last winter when the water <br />was around 45-50 degrees (I live in Texas) and it seems to "kick in" a little sooner now that the water has <br />warmed this summer <br />4. Could I be dealing with a thermostat malfunction........although it would seem (at least to me) that if it was a cooling <br />problem related to a stuck thermostat that the transition would not be so abrupt. BTW my overtemp warning horn <br />has never gone off. <br />5. A friend with a newer Johnson said that in his book that there was an electrical component that allowed tha motor to <br />operate during a overheat condition at limited rpms supposedly to get you back to the ramp. Does my motor have <br />this feature.........It says nothing about it in my book. <br />6. Could I be dealing with a malfunctuion with the check valve in the fuel line downstream of the bulb........like I said <br />earlier you can pump it up but not to rock-hardness.........it will always allow for more squeezes. <br />That's about all the info I can give unless any of you guys want to ask any questions.............any help would be greatly <br />appreciated. <br /><br /><br />thanks <br />Benny
