hunting2much
- May 3, 2006
- 6
After hitting a stump, my T&T has been acting up and is now leaking fluid around the trim motor. It will only rise about halfway and will not come down. I can manually release it down and it will work again. Until I lift it to high again.<br /><br />The Leak --- Would the force of the motor coming down after hitting the stump blow the o-ring around the trim motor?<br /><br />Also, while replacing a burnt trim motor a couple of weeks ago I noticed the hydraulic fluid was a gray color. Is that referred to as "Milky" (water)?<br /><br />Thanks in advance for you time!!!
