No more BEEP when I turn the key.
fconna
1988 Johnson 110 V4 VRO J110TLCCA<br /><br />After water pump and thermostat replacement, the boat was run on the hose @ idle for 15 minute and 5 min at 2500 rpm. everything AOK. Off to the boat ramp.<br /><br />Boat ran @ idle to the El Jobean inlet of Charlotte Harbor, power up to plane running 3000 rpm for 4 or 5 minutes experiance a loss of power and a BEEP,BEEP,BEEP. <br /><br />Fished for 20 minutes started moter and ildled back to Port O' Call and brought it home.<br /><br />Engine runs fine on the hose. However, now there is no beep when I turn :confused: the key.<br /><br />Thank you in advance for your help.<br /><br />Robert
