I bought a 1989 Bass Buggy Pontoon two weeks ago. I took it straight to water and it ran great. Started easily, ran strong. Ran the boat for 3 days with absolutely great performance. The next week I took it out and the battery was dead. I charged the battery and it hasnt started since.<br />What I have done so far:<br />-Checked the plugs, they are getting nice blue fire (bought new ones anyway, set gap at .30???)<br />-There is fuel reaching the plugs, maybe too much??<br />-Charger battery back to 13.7 volts<br />-Compression on both cylinders is right at 125 psi.<br />-it is oil injected and the tank for the 2 stroke oil is full<br />-When I crank it it will occasionally backfire through the exhaust<br />-One thing to note is that the area I bought the boat had a different fuel being sold, my area of Virginia sells gas with a 10% blend of ethanol, the area the boat came from did not have ethanol.<br />-when I pumped up the bulb for the gas I could not get it to tighten and fuel came from the bottom plug hole, I tapped on both carbs figuring a stuck float and the bulb tightened<br /><br />I have drained the battrery a dozen times trying to figure out what is going on and figure I will need a new starter before this is over....HELP!
