  #1
Old April 30th, 2002, 03:50 AM
PsYcHo PsYcHo is offline
Default 115 Mercury running rich/smoking
Hi, Im a newbie so please bear with me 115HP, 6 cylinder Mercury outboard, has been standing 6 years. Previous owner never drained the carbs of fuel before storing. I have drained all old fuel out, replaced fuel line hoses and fuel filter. New spark plugs. Fresh gas/oil mixture (50:1) Starts easily. Smokes quite a bit! All cylinders are firing. Apon inspection of plugs....they have a little oil on them, and what appears to be normal carbon deposits.I have taken the boat out on the water (21 foot speedboat) Motor reaches 5000 RPM but feels rough with the odd hick-up sound. Motor idles a little ruff.So basically it smokes alot no matter what RPM....but the smoke is strong smelling if you know what I mean....unburnt fuel perhaps? Its as though the carbs are not getting enough air! If I disconnect the fuel line and the fuel in the carbs gets used up....it almost runs better/smoother as the fuel gets less just before starving. (If that make sense)So here is my question: What do I do? Is it running to rich? And if so...could that 6 year old fuel in the carbs have clogged up passages? Could I use a carb cleaner to rectify the situation?
  #2
Old April 30th, 2002, 08:33 AM
Yepblaze's Avatar
Yepblaze Yepblaze is offline
Default Re: 115 Mercury running rich/smoking
Pull the carbs, dissasemble, and clean out all the jetss and passageways. If the old gas had "varnished up" it may take some light probing to release any hardened deposits. Here this might be of some value although not model spacific. http://www.dgweb.com/~bobaloo/Carbclean/CarbClean.htm
  #3
Old April 30th, 2002, 08:39 AM
Yepblaze's Avatar
By the way, some smoke at startup and idle will occur normally. Make sure you mix the gas oil well. If portable tanks add oil to half tank and swish well before adding the rest of the gas. If built in tank add gas, oil, gas, oil, gas, oil, in icrements or add oil to a few gallons in a jug then add to tank along with additional gas. Use a calculator, and keep one handy. Start your equasion with 16 divided by 6 = 2.6666oz per gallon. Be accurate.
  #4
Old April 30th, 2002, 11:28 PM
Thanks Yepblaze,Great URL for a guy who has never striiped a carb before! Stripped the carbs last night-->easy as pie! Surprisingly they were very clean! Save for one of the carbs having a blade of grass (like as in lawn)in the float chamber. Floats look good....no wear on the needles etc. Could see someone had it open before.....damaged bolt/screw heads etc. All gaskets look good aswell, so I guess I dont need to get a carb kit which is expensive around here (around $80 each and I need 3...expensive for us folks)Thanks for your help....will fit the carbs today and let you know how it goes. Only puzzling thing is that the carb only a mixture screw....seems idle is set by the distributor advance. Any idea as to how I should set this one and only screw? Its a WMK-25 mercarb.
  #5
Old May 1st, 2002, 12:27 AM
Joe S. Joe S. is offline
The mixture screw you are talking about is probably the air mixture screw. Gently screw it in all the way until it is seated, then back it out the manufacturers number of turns. The idle mixture is preset at the factory by jetting. The timing could also be present on that motor but I'm not too sure. The best thing you can probably do is get a manual. Good luck!
  #6
Old May 1st, 2002, 07:38 AM
michaelsen michaelsen is offline
Yepblaze, I am messing with a Merc 115hp 6 inline from 75 and just finished the carbs. Turn the screw 1 1/4 turn out and it should work fine.
  #7
Old May 2nd, 2002, 05:35 AM
Thanks for all the help! Got her up and running and she feels much better! Just need to check the timing as its not running perfectly yet.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Running Rich?? 02baylinercapri-NM Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 5 March 10th, 2005 11:15 AM
92 OMC 4.3 running rich jdoane3414 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 7 October 26th, 2004 06:48 AM
92 OMC 4.3 running rich jdoane3414 Non-Repair Outboard Discussions 1 October 25th, 2004 12:06 PM
Mercury 150 running rich on low end. springcreekranchusa Mercury & Mariner Outboards 4 August 8th, 2003 11:01 AM
Running Rich? jgm7739 Yamaha & Suzuki Outboards 3 June 16th, 2003 11:20 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
