Re: my motor wont stop
Does this motor have a shift assist switch? If so, a bad diode in the wiring that's attached to the shift assist switch can prevent the motor from stopping completely when the key switch is turned off. The diode feels like a little lump in the wiring. Test for continuity. The wire with the diode should have continuity in only one direction if the diode is good. If the motor does shut off completely with the key switch but not with the kill switch then you have a bad kill switch.
