I have a 1985 25 hp evinrude I'm trying to remove the lower unit to replace the water pump I first had problem with the front stud was stuck in the leg I managed to get it aloose and now the shifter linkage is still attached. I'ved looked at the other post on the the site and i have not found the window on the leg to remove for access. I would really appreciate it if some one would tell me the correct way to disconnect the shift linkage. Thank you for any help.<br /><br />Bucyrus
