RichardWooster
- Jun 15, 2006
- 3
I have a 30hp Evinrude that will not pivot right or left with the cable removed regardless how hard I push upon it. Steering cable works fine when disconnected and wheel is turned. Problem is either the horizontal tube (name?) into which the steering cable is insterted to push/pull on the steering ram arm, or the vertical tube (name?) on which the engine head is supported. My shop manual does not identify these parts, discuss this problem or suggest how to remove the parts. Other posts suggests ram arm is most likely frozen in the horizontal tube and the fix is penetrating oil, a bfh (big fricking hammer with punch rod), heat and patience. Can anyone name the parts and suggest a fix and source for parts I break.
