  #1
Old April 19th, 2002, 09:44 PM
awaschka awaschka is offline
Default 94 Mercury 115 Shutdown, has low compression
The motor is a 1994 Mercury 4IL electronic ignition carbureted 115HP.I was running at about 2800-3000 rpm when the motor shut down like I pulled the throttle back.I tilted it up and checked the prop for damage and found none.I cranked it and it started it right up, but it was making a slapping metallic noise at idle.I carefully advanced the throttle and the noise went away.I ran it back home at lowest speed to keep on plane and the engine sounded and operated normally.I listened all over it and could not localize the noise, but it was a definite metallic slapping sound.I pulled the boat - had to run it over to the ramp about 3 miles, again sounded normal at low speed plane.In the driveway with the flushette on, can barely hear the noise over the exhaust, but can hear it as engine coasts down if turned off at about 2000 rpm.Pulled the exhaust cover and #4 piston is scored on the near side. Cylinder walls have minor scoring on the opposite side (can't see the near side) obscuring the cross hatch pattern visible in the other cylinders.Compression is 145-150 in #1, #2, #3 but 87 in #4.Got the power head ready to pull. Will check the cylinder for wear and try honing it first, then maybe get it bored for OS piston.Looking for help on what might have happened.Engine seems to be getting plenty oil, maybe even too much. Lots of blue smoke at idle and when I checked the oil injection pump setting it looks like it is set a little rich.This engine does not have idle jets in #3, #4 carbs. I wonder if it gets enough lube in those cylinders at low speeds.It is also bad about lag coming out of the hole, particularly the first time after no use for a while.I'm thinking about buying new carb bodies for #3 and #4 like #1 and #2 that have idle jets, but using the #3, #4 main jets.Any ideas about what to look for as the cause of the problem and whether the carb change is a good idea?Thanks,Al
  #2
Old April 19th, 2002, 11:06 PM
skier skier is offline
Default Re: 94 Mercury 115 Shutdown, has low compression
Sounds to me like that cylinder wasn't getting enough oil. I sucked a reed valve on a 70 Merc 1250 and #5 didn't really score the cylinder walls, but did mega damage to the piston. #5 had 5# of pressure and it still idled. I had to go to the other end of Trinity Lake in CA. about 15+ miles (Thank GOD that the water pump worked great. Kept the motor from seizing)I think that the carb change would work just fine, in fact I never liked the 2+2 indea in the first place, That's why I went with one of the last inline 6 "Towers". If you can get the #1 & 2 carb for 3 & 4. I think that you'll be surprised with the hole shot with all four online all the time.Good luck and keep us postedCraig
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Please Help! Mercruiser shutdown Diana Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 8 November 17th, 2006 02:01 PM
I-Boats shutdown. Tyme2fish Dockside Chat 0 December 17th, 2005 03:54 AM
I-Boats shutdown. Tyme2fish Dockside Chat 0 December 17th, 2005 03:52 AM
Computer won't shutdown Tyme2fish Non-Boating Technical Topics 7 July 14th, 2005 03:56 PM
25hp Mercury 2 stroke shutdown query noolster Mercury & Mariner Outboards 5 July 2nd, 2005 09:50 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
