Head gasket question?
GatorMike
Ensign
I suspect my 115 has a blown head gasket. The way I came to this conclusion is outlined in another thread I posted titled (troubleshooting a poor running outboard). Anyway I was checking prices for a new gasket on Iboats.com and noticed for some models they offered both a head gasket and a low compression head gasket. What exactly is a low compression head gasket and is there any reason I should order the low compression gasket over the regular one?
ob
Re: Head gasket question?
A low compression head gasket is a thinner material gasket.Sorta like shaved heads.Slightly shortens the depth of the combustion chamber at top dead.I would just order the conventional one.
D
DJ
Guest
The low comp. gasket would have been for engines used in markets with low octane/poor quality fuel.
ob
I think DJ has it right and I'm bassackwards on my first description.I believe the high compression head gasket is the thinner and the low compression one is thicker.My bad.
