I saw your previous post, and pondered it for quite a while. How do we explain the routing here?
I thot a makin a pic of the one out in the yard, but it was too dark, and I have no idea how to post a pic here. I could've Emailed it, but do't know your email add.
But I'll try to explain it as simply as I can.
Under the cover,port side front, there is
a plastic pulley on a post. This acepts the two cables from the tiller.
Turn the tiller control to WOT, and note which cable pulls-in. This will be the cable to connect to the outer-most (port-most)
cable point on the plastic pulley.
I tried. good luck.
