98 115 Johnson<br /><br />I just got back from a week vacation on Marco Island and need to look into a problem I was having all week. I realize I was taking a chance running a poor running outboard for that long but had my sons and grandchildren depending on the boat as the center piece of their vacation so I took the chance.<br /><br />Before leaving Orlando I tested the boat out in a lake and she seemed to run fine. When I got to Marco and put the boat in the water she seemed fine. I motored through the no wake zone and had no problems but after I hit open water on the way to the condo she shut down on me. She did this twice and several times the following morning. I will make this quick since I fixed that problem the next day. I replaced the powerpack and solved that problem. Since all the parts places would be closed over the Memorial day weekend I also bought one new ignition coil in case I needed it.<br /><br />For the rest of the week my motor developed a pesky little problem. She seemed to run smooth at full throttle and high RPMs but at idle speed and low RPMs she had sort of a lean cough. This was an intermit problem and happened about 50% of the time. She seldom stalled, only when she was running her absolute worst. Around mid week I decarbed the engine and cleaned the carburetors and drained the bowls and also changed out a couple of the ignition coils with the new one I had bought earlier with no change in the way she ran. <br /><br />Now that I am home I plan on doing a compression test and removing all the electronic parts and clean all the contacts and engine grounds to start. Then I will probably remove the carburetors and rebuild them. I am not sure if this is going to help but seems like a good starting point to me. Does anybody have any Ideas what might be causing the little cough the engine has at low RPMs?
