  #1
Old March 13th, 2002, 02:59 PM
mike b. mike b. is offline
Default merc/mariner tachometer wiring
I'm having problems with erratic readings on my tach.I've checked the connections and settings on the tach side.Does anyone know where the tach wires connect on the motor or what color?Motor is an 1998 cabureted Mariner 150.I saw a electronic box on the right side(from rear)near starter that had terminals with rubber caps on them.By those terminals were raised words reading white,brown etc. What was that?Any help is appreciated.
  #2
Old March 13th, 2002, 03:22 PM
Trent Trent is offline
Default Re: merc/mariner tachometer wiring
Tach is the gray wire... Make sure your battery is charging..Above 13 volts. Tachs that starts acting up are the first indication of a charging system problem (they are connected electrically).The box you are talking about is the CDI or Powerpac (electronic ignition).
  #3
Old March 13th, 2002, 03:40 PM
Trent my voltmeter reads steady at 13-14 volts at idle.The gray wire goes to the powerpack?
  #4
Old March 14th, 2002, 07:26 PM
novacane novacane is offline
corect me if im wrong but arnt these outboard tachs read a diode pattern for rpm mesurment if this is true grey to hot blk to ground im no boat tech what so ever i could totally be wrong :o
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
OMC Tachometer Wiring ruddy Non-Repair Outboard Discussions 7 February 9th, 2007 12:40 PM
Tachometer wiring for 1979 Merc 90ph slyem2002 Electrics, Electronics and Trolling Motors 2 July 21st, 2006 04:11 PM
Tachometer wiring compoundxx75 Johnson & Evinrude Outboards 2 July 29th, 2005 09:02 PM
Tachometer wiring jaba Force & Chrysler Outboards 2 April 20th, 2004 08:51 AM
85 merc mariner wiring diagram camstans Mercury & Mariner Outboards 2 October 26th, 2003 02:35 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
