  #1
Old March 9th, 2002, 11:05 AM
Chris Stevens Chris Stevens is offline
Default 1973 Mercury 20 hp diagram
Does anyone know where I can find a very simplistic diagram of the outside of a 1973 Mercury 20 hp outboard?? I need something that shows the location of all external controls (throttle, choke, forward/reverse, etc.) I have a mercury service manual for that year, but the information is very technical..I just want to know where all the controls are.
  #2
Old March 9th, 2002, 05:24 PM
steverino steverino is offline
Default Re: 1973 Mercury 20 hp diagram
I have a motor exactly like yours. What exactly are you trying to figure out?
  #3
Old March 9th, 2002, 07:02 PM
Steve, I'm trying to figure out where the throttle is (is it in the tiller handle?), where the forward/reverse is, and really just how to start and use this engine properly. Quite frankly, I don't know a thing about outboards (or engines in general) I'm used to rowing around in a dory), and I'm trying to get the basics about outboard operation, particularly the starting, stopping and shifting procedures for this motor.
  #4
Old March 10th, 2002, 01:32 AM
Chinewalker's Avatar
Chinewalker Chinewalker is offline
Hi Chris, Here we go... looking at the front of the motor, on your left, on the side of the motor is the shift lever. There should be some letters on the motor, nearby, F-N-R for forward, neutral and reverse. On the front face, left to right, there should be a choke knob, kill switch button (might be on the side, near the shifter, as they moved it at some point in the early 1970s), and the fuel connector fitting. Connect the fuel tank fitting here (push and twist), prime the queeze bulb in the fuel line until it won't squeeze easily. The throttle is indeed on the end of the tiller handle. With the motor in neutral, you can advance the throttle to the stop (when it won't advance any more), pull the choke (for cold motor only), pull the recoil handle out until resistance is felt, then give 'er a yank! Make sure the motor doesn't race - be quick to reduce throttle if it starts to rev up. Shifting should only be done at slow idle - as slow as it will go without stalling - don't depend on the "shift" zone marked on the throttle handle (if the marks are still there). Check for a strong stream of water coming out the "pisser" in the rear, left (from your vantage point) side of the motor. Some water may also come out of the slots in the upper portion of the motor leg. They're a good strong motor, but you have to take care of them (like anything else). If the motor is new to you and you're unsure of the service history, I would take it to a Merc service guy and have him install a new water pump impeller and check the lower unit oil.- Scott
__________________
Share A Project Page for 1971 GW Invader Banchie 13
http://www.shareaproject.com/pages/p...,p,433,00.html
Share A Project Page for 1976 American 18
http://www.shareaproject.com/pages/p...,p,404,00.html
Share A Project Page for 1974 American 15
http://www.shareaproject.com/pages/p...,p,405,00.html
  #5
Old March 10th, 2002, 01:34 AM
Hi again Chris, If you want to get an owner's manual, they often turn up on eBay or you can order one from Grubb's Marine (www.oldmercs.com). That will have a much more "user friendly" guide to general usage stuff than a service manual...- Scott
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1973 Yamaha outboard diagram ent Yamaha & Suzuki Outboards 5 August 27th, 2003 11:28 AM
Need a wiring diagram 1973 Evinrude Chris Schlaupitz Johnson & Evinrude Outboards 3 June 19th, 2003 09:18 AM
wiring diagram 50 hp mercury Rusty B. Mercury & Mariner Outboards 1 February 13th, 2002 04:17 AM
1973 65 hp engine diagram esincl40 Johnson & Evinrude Outboards 2 July 20th, 2001 09:10 PM
Need 87-88 Mercury 115 Wiring Diagram fishnfool2 Mercury & Mariner Outboards 1 July 7th, 2001 11:35 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
