  #1
Old August 5th, 2001, 06:39 PM
bob williams bob williams is offline
Default mariner gear box
my mariner 40 hp started kicking out of gear going flat out, it would reengage right away though, it also grinds some going into reverse, am i lookind at a lower unit rebuild?
  #2
Old August 6th, 2001, 01:03 PM
grandx grandx is offline
Default Re: mariner gear box
Hi, just going down the list looking at the 0 replies only, I hate when no one looks at mine. Here goes.. Check and make sure shift linkage is correctly adjusted and that you are truely going into gear fully and not just half way. Grinding goin in reverse? Every engine has an appropriate RPM at forward gear idle, make sure you are within that range, Idling too high can make it difficult to shift. Should idle as low as possible, yet still idle and not die in forward gear (no extra throttle). If none of this works for you, drain oil from lower and look for water, metal chips etc and note condition of oil. If gears are worn they will be in chips in your gear box. Some shavings are normal wear, wish I could tell you what too many looks like. You find alot of metal you probably need a rebuild. Hope this helps some.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mariner gear shift rahn112 Mercury & Mariner Outboards 1 August 10th, 2006 03:32 PM
Mariner not getting rmp's in gear shelbik Mercury & Mariner Outboards 4 July 1st, 2005 05:32 AM
Mariner 15 gear selector help Fishbreath47 Mercury & Mariner Outboards 0 October 26th, 2003 07:08 AM
Mariner 15 gear selector Fishbreath47 Mercury & Mariner Outboards 2 October 11th, 2003 07:29 AM
5 hp mariner won't go in gear zon Mercury & Mariner Outboards 2 May 28th, 2001 05:11 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
