  #1
Old February 6th, 2002, 02:09 PM
RobAz RobAz is offline
Default 60Hp Mariner wont go into gear
I have a 87 60Hp Mariner. I just changed out the impeller and now that I have everything back together it won't shift into gear. Looking at the shift linkage everything appears OK there. Hopefully you can tell me what simple thing I have done wrong. Thanks Rob
  #2
Old February 6th, 2002, 02:31 PM
petryshyn petryshyn is offline
Default Re: 60Hp Mariner wont go into gear
Think carefully, did you have the shifter shaft out of the gear box? Did you have any of the spacers off of the shifter shaft? There is a reverse cam lock assmy that must be in proper synch if I remember right. These pieces just slide down over the shaft and are splined. Try shifting her with the cam lock removed....then you'll know if its related to the lock mechanism....do you have a manual with a parts break down?good luck!
__________________
Alias "schematic"
  #3
Old February 6th, 2002, 02:59 PM
Dmzhmdepo Dmzhmdepo is offline
Rob,I have a 74 Merc. 40hp and have done what sounds like you just did. I changed my impeller and put it back together. However mine just stays in forward gear. Do you have a plastic spacer with two wings and a plastic cam that sits on the spacer? Dmz.
  #4
Old February 6th, 2002, 04:31 PM
ODDD1 ODDD1 is offline
C'mon guys....motor works...take off gearcase an reinstall...now motor doesnt shift... both you guys missed the shift shaft on the reinstall...gotta drop the case again...
  #5
Old February 6th, 2002, 05:26 PM
ODDD1,Sorry, but had the unit together and running perfectly except that it stays in forward gear. And , the tilt lock worked perfectly when shifted.....so ...don't think I missed the shaft. (went together smooth) Also, there is an alignment spacer in the upper case that holds the shaft in place. Am sure it mated. Thanx. DMZ.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
plugs wont fire on a 1986 60hp mariner workman_teddy Mercury & Mariner Outboards 3 June 1st, 2006 01:51 PM
1986 Mariner 60hp not going into gear wgp Mercury & Mariner Outboards 1 July 4th, 2004 01:01 PM
115HP Mercury starts in gear, wont get out of gear adamc91115 Mercury & Mariner Outboards 3 July 15th, 2003 03:49 PM
60hp johnson wont idle marcel Johnson & Evinrude Outboards 1 August 12th, 2002 09:23 PM
'87 Mariner 60hp stalls into and out of gear. RAB1397 Mercury & Mariner Outboards 5 July 12th, 2002 06:16 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
