  #1
Old February 6th, 2002, 11:24 AM
bigwillie bigwillie is offline
Default Mercury 20hp...power loss when going full throttle..but not all the time?
Mercury 20hp, only about 3 years old, just got it tuned up....now, when I put it in the water and go to full throttle, the motor will go for a few minutes and then it seems to suck air. Then the the motor wont push past wake speed..It will run at idle speed and starts on the first pull....but this dosn't happen all the time..Sometimes I go out and it will work with no problems...I could understand it if the motor did this all the time..but its only a select number of times....Brought it back to the boat shop and they ran it in their tank with no problems..I took it back out and it happed 2 out of 4 times I was in the water...Its seems that when the boat begins to plan off, the motor will start slowing down like its running out of gas....Any clue to what might be the problem..
  #2
Old February 6th, 2002, 11:38 AM
petryshyn petryshyn is offline
Default Re: Mercury 20hp...power loss when going full throttle..but not all the time?
Sounds like you're losing one cylinder. Before getting too involved, try putting the old plugs back in. I've seen new ones defective which develope intermitent missfire. I assume new ones were put in at the time of tune up....
__________________
Alias "schematic"
  #3
Old February 6th, 2002, 11:40 AM
12Footer's Avatar
12Footer 12Footer is offline
Does it act like a slipping clutch on a car? If it does, the hub has spun out of the prop.If the engine is not stumbling, but the boat just doesn't want to go, this is the problem.
__________________
"Did you hear about the guy whose whole left side was cut off? He's all
right now."
  #4
Old February 6th, 2002, 12:12 PM
it feels more like a fuel problem than a motor problem.....the plugs are fine...the engine isn't miss firig..its when you go to throttle up it will go but then the power will come down to about idle speed...
  #5
Old February 6th, 2002, 12:48 PM
kevlar3000 kevlar3000 is offline
How is your tank and your fuel line? A tiny air leak can cause lots of problems. Water in the tank could also contribute.There has been more than one bag spark plug sold, the idea with using the old ones is to see if the problem persists. Or even try a different new one if the old ones were tossed. I too would think if it worked ok at the shop it has to do with your fuel delivery...Keep us posted....
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
power loss at full throttle dansys3 Johnson & Evinrude Outboards 3 August 1st, 2005 11:15 AM
Power loss at full throttle HELP!!! gramkaran Mercury & Mariner Outboards 4 September 30th, 2004 09:30 AM
No power from 20HP Merc at full throttle JFNStuart Mercury & Mariner Outboards 5 September 13th, 2004 01:57 PM
loss of power during full throttle noshelter Johnson & Evinrude Outboards 2 July 15th, 2003 06:28 AM
Power loss at full throttle earlybird Force & Chrysler Outboards 1 June 6th, 2002 08:31 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
