  #1
Old February 4th, 2002, 04:20 AM
snookaddict snookaddict is offline
Default 91 75hp Mariner, No Shift.
Last time out the motor started banging and clanging so I shut it off and got towed in. 4 months later I have replaced all pistons, rods, bearings, seals, etc. Reassembled the motor and got it running great, but now it stays in Forward gear. It will not shift to neutral or reverse. Motor was shifting fine before powerhead problems. Took lower unit off and turned the drive shaft while slowly turning the shift rod and I can't feel that it is doing anything. Can this happen from sitting for 5 months and it just needs to be ran? Can't afford a new one please help.
  #2
Old February 4th, 2002, 06:54 AM
skier skier is offline
Default Re: 91 75hp Mariner, No Shift.
Try this, Put the lower unit into reverse AND the control into reverse. If that doesn't fix it, then try both in forward gear. Hope this helps/works
  #3
Old February 5th, 2002, 04:23 AM
I haven't had the opportunity to run the motor for an extended period of time since the powerhead rebuild. I can only run it in forward now and even with the motor running when I shift the controls to reverse or neutral the motor is still in gear. Disconnected the shift cable and rotated the shift rod freely and still no change. When in neutral should the prop spin freely without clicking in both directions? Thank You.
  #4
Old February 5th, 2002, 01:53 PM
omctech omctech is offline
Your problem is in your lower unit. Try taking the lower off, and with a pair of pliers, shifting manually into neutral. The prop will spin freely in both directions. Then shift back into forward. Your lower will ratchet in both directions.(make noise) With the lower in forward, shift your control box to full forward and reinstall your lower unit. This should eliminate your problem.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
mariner 75hp 1997 raptorheli2 Mercury & Mariner Outboards 2 November 12th, 2006 03:31 PM
Mariner 75hp goff Mercury & Mariner Outboards 3 August 25th, 2003 01:33 PM
1961 75hp johnson shift problems djavine Johnson & Evinrude Outboards 3 August 18th, 2003 05:22 PM
75hp Mariner oil alarm AZO Mercury & Mariner Outboards 1 July 11th, 2003 09:50 PM
Mariner 75HP stemar Mercury & Mariner Outboards 1 January 2nd, 2002 12:19 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
