Re: Removal of V4 Tilt/Trim
posted 22 March, 2006 08:23 PM <br />--------------------------------------------------------------------------------<br />I just finished doing this on the Old 92 V8 Johnson.<br />Two days later I have two broken drift pins and one broken easy out. Plus a bandaged thumb.<br />Items needed.<br />1.Hi temp propane torch, and use Mapp gas.<br />2. 1/2 inch drill and assorted bits. <br />(your gonna ruin a few)<br />3. A B.F.H. and a regular hammer.<br />4. Assorted length Drift pins.<br />5. Be nice to have a (not to bright friend) hold the Drift pin whilst you whack it.<br /><br />Drill a hole in the pin so you don't mushroom it over while hitting you friends thumb with the BFH.<br />Use the high temp torch to heat the aluminum surrounds both sides of the pin to allow the rusted pin enough room to move while you wail on it. Not to worry you will not feel a thing as you miss and smack your friend thumb instead of you own. <br />The hardest part is realizing you gotta really smack it HARD to get it to budge at all, even with the heat.<br /><br />Hope this helps! If you can afford to pay someone to do it
it might be a good idea. LOL
