Impeller replacement 1970 115
tcreech
The parts breakdown (BRP site)shows no gaskets above or below impeller plate (or anywhere under housing for that matter). Is this correct? The only impeller I've replaced was a Merc, which had gaskets above and below plate, IIRC.<br />If no gaskets, then I would only need:<br /><br />Impeller<br />Driveshaft seals (below impeller)<br /><br />Am I right?<br /><br />Thanks,<br /><br />TC
Tom Scully
Re: Impeller replacement 1970 115
Just did a 72 and it did not have a gasket above or below the plate. <br />There is a rubber "o" ring which lines the bottom of the pump housing.<br />I am in the habit of changing all of the components at the same time, including the impeller, pump housing, the metal pump liners the shaft key, "O" ring and lower plate.
