Re: Fuel problem?
Sync & link can be critical on these 3 cylinder engines, is this correct on your engine? What are the compression numbers? Reed valves are a rare problem, fuel would be spitting back through the carb on the offending broken reed, and carb assembly. A running test on the ignition system would be a good idea. You have something breaking down, Compression, ignition, fuel, you have to detirmine which one. On an engine this age, I would remove the cylinder head, and have a look. There seem's to be a reluctance to remove a cylinder head on a 2 cycle engine. It is nothing but a cover, or seal, with no moving parts.It will save a lot of time, and searching in short order. Finding a scored clyinder, or scuffed piston will save a lot of time, and money in needless parts.
