tdevince, the only time i have seen an oil injection failure cost $1500 to repair is when the operater didnt heed the warning horn.....oil injection gears on these motors fail from these things:
engine over heat causing plastic gear distortion
oil seal backing out of pump and binding oil pump drive
oil injection check valve that is stuck and over pressurizing oil pump...this check valve is on the outlet side of pump and should pass oil at 2 PSI..have seen some would not pass at 10PSI
poor installation of oil gear/ or rough handling of driven gear at install
finally, the #1 reason, the 1 all the racers take oil inj. off their motors for....over revving the engine...the high side of 6 grand will take these gears, its just a matter of time
you can say merc oil injection is junk,heck allotta people do, but think about all the motors built with it since 1984, its been ALOT...an the vast majority never had a lick of trouble....
