how or what is the carbs setting for this motor <br /><br />its a 1995 90 evenrude<br /><br />the right bank of carbs ,was inop. and i rebiuld them<br />the carbs wasn't getting any gas so i check the feul presure and its was ( 5 psi) and when down to 0<br />the i took a vacuum test at the pulsator<br />that was that was (5 in)went down to 0 ,so i replaced the pulsator and everything came back to normal,but the engine still has an idling problem this engine will not stay running for more then 2 mins. by it self. i'm thinking that there is an ignision problem, but running out of ideas to fix this problem<br /><br /><br />can anyone help<br /><br />coils good <br />spark plugs good<br />wires good<br />timing good <br />cylinder timings is good
