hello to all. I have a 125ESL71C with shift problems. I will begin with this motor problably hasn't ran in 5 years. I read the post about what to do with a motor that has sat for a while. I also have the seloc manuel (I know) and have ran some checks using this mauel. I checked the solenoids to ground and blue wire was 6.0 ohms and green wire was 5.5 ohms. I checked the voltage while running and voltages are fine. Shift switch appears to be working accordingly. It will shift into reverse but will not work in forward. Now if I understand this correctly this unit, when no power is going to the shift solenoids, spring loads to forward. So do I have a bad spring? Oh and also I have put Citgo Marine plus gear lube which states it is for "type c" lower units. The lube that was in there before was not type c (I found the tube on the boat). Another thing I have not had the motor in the water yet, just on muffs. Any help would be appreciated.
