  #1
Old July 18th, 2005, 08:06 AM
jwharan jwharan is offline
Default Used Boat Test Drive -- Issues
I test drove a boat yesterday that I am buying. I have a few issues that I could use some help with.First, The boat starts and idles properly, but tends to stall when I try to go into gear. Even if i throw the gear down hard, it wants to stall about 50% of the time. I want to say the engine just sounds like it is running way to rich. Once I am in gear, and moving around, the boat runs great.My next question is probably my misjudgement and not the boat. First, i am not sure how to use Trim, Should it be up down or in the middle? when do i need to adjust it? 2nd, If I accelerate beyond a certain point, or too quickly, the boat seems to "spin in place" the RPMs shoot up, but the boat doesn't go anywhere. I have to throttle down to almost neutral, in order to regain momentum. Also, sometimes the boat will shake when I accelerate to fast, perhaps this has to do with my trim setting, not sure. Can anyone offer some advice to my issues here? Thanks!
  #2
Old July 18th, 2005, 08:19 AM
milkyway milkyway is offline
Default Re: Used Boat Test Drive -- Issues
Just for testing the boat, keep the trim all the way down to keep it simple for yourself. If you have it at the wrong angle, you may experience problem accelerating from a stop position. But until you get to get the engine to run correctly, the boat may not plane at all, or just barely planing but without enough power to continue. If the boat shakes when you are accelerating, could be engine. You must first have the engine run 100%. If the trim works up and down, then the trimp is working. That should be your concern for now about the trim. Can you give more details about this boat?
  #3
Old July 18th, 2005, 08:39 AM
GarySutherland GarySutherland is offline
I'm assuming from what you've said that it's got an outboard motor. Have you checked the engine is suitable for the height of the transom? i.e. short-shaft/long-shaft?It sounds as though at full throttle the engine is running out of water, suggesting that the engine is too short for the boat.My own boat suffers from this and I believe it to be just this; short shaft engine and built-up transom more suited to long-shaft.CheersGary
  #4
Old July 18th, 2005, 08:40 AM
The Boat is a sea ray 185, 4.3 merc 190hp 18.5. Boat planes fine. The trim does work, i just don't how to use it. What else do you suggest, what about the "spinning out" problem?
  #5
Old July 18th, 2005, 08:45 AM
txswinner txswinner is offline
Banned
Get compression checked on all cylinders, because I have limited knowledge I always have boat checked about $100 to $150 by boat motor mechanic, good luck.
  #6
Old July 18th, 2005, 10:15 AM
Does anyone else have any comments on any of my other issues? In addition, the speedometer, is not working.
  #7
Old July 18th, 2005, 10:44 AM
KCook KCook is offline
Stalling when going into gear and the boat shaking should be your number 1 concerns. The other is minor stuff. As txswinner already said, need to have a professional look at this.Kelly Cook
  #8
Old July 18th, 2005, 11:04 AM
umblecumbuz umblecumbuz is offline
Hi Jwharan,This 'spinning out'. it sounds like the prop is pulling air, from the way you describe it. You say you're not sure how to trim. This could be as simple as having the outdrive trimmed out too far. Do as Milkyway suggests - trim the outdrive all the way in (propellor nearest to the transom), and give it another run.The stalling when engaging gear could also be simple, such as a mixture or slow idle adjustment.Ain't anything wrong with grabbing a mate who's used to boats and getting him to go along with you.
  #9
Old July 18th, 2005, 11:17 AM
Quote:
Originally posted by Stillfishing: Hi Jwharan,This 'spinning out'. it sounds like the prop is pulling air, from the way you describe it. You say you're not sure how to trim. This could be as simple as having the outdrive trimmed out too far. Do as Milkyway suggests - trim the outdrive all the way in (propellor nearest to the transom), and give it another run.The stalling when engaging gear could also be simple, such as a mixture or slow idle adjustment.Ain't anything wrong with grabbing a mate who's used to boats and getting him to go along with you.
StillFishing:I think you are pretty on with this. can you talk about the spinning out part a bit more. If i was to describe it more, I would say that it feels like knocking a car into neutral, while accelerating. The RPMS jump way up, and the speed drops off.
  #10
Old July 18th, 2005, 11:25 AM
Banned
In boating it is often referred to as cavitation. It is when the prop is sucking air and increases rpm without water to increase accelaration of the boat. The motor needs be trimmed all the way down to the stop. This should eliminate the problem. If not you should have the prop checked as it may be damaged.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Volvo 3.0L SX Drive Issues neald Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 October 28th, 2006 03:12 PM
New boat test drive 496 Cubic Inches Non-Repair Outboard Discussions 7 February 11th, 2006 04:53 AM
'69 Evinrude 85hp v4 - starting issues - ? on test in manual sianyde Johnson & Evinrude Outboards 0 August 11th, 2005 04:55 PM
Stern drive issues colver1 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 July 27th, 2005 06:30 AM
Used Boat Test Drive -- Issues jwharan Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 20 July 19th, 2005 06:40 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
