  #1
Old July 17th, 2005, 06:43 PM
swade28 swade28 is offline
Default Center Console livewell broken/ 1997 Cajun 2100 fishmaster
I have a cajun 2100 center console that the livewell has come separated. It seems the only way to repair this the right way is to turn the console over and re-glass it back to the console. Would this be very hard to do and is their an easier way. Seems all the controls/wires would have to be unconnected? If this is so I was thinking of building a floor for the live well to rest on in the future that would fit just above the gastank and below the livewell. Any suggestions greatly appreciated. Thanks, Scotty
  #2
Old July 18th, 2005, 07:18 AM
seadiva seadiva is offline
Default Re: Center Console livewell broken/ 1997 Cajun 2100 fishmaster
hey how ya doing, boy i dint know how you would fix that. at least not an easy way. i would like to know what caused the break, just the pounding from rough water? i have a 21' cajun cc 97 model. ive been lucky so far and not have had this problem. i did this weekend change the pump for my livewell. good luck.
  #3
Old July 18th, 2005, 05:44 PM
just the pounding with it being full is the only thing i can think of. If I were you I would see about putting some wood between the bottom of your well and the gas tank to help stabilize it. Scotty
  #4
Old July 19th, 2005, 07:18 AM
hey i just may try that. this is a tough boat it sure has taken alot. it sure handles the water well, all upand down the coast and out in the gulf, and many of the lakes. good boat. do you have that red lever on the side of the console? what is that for, do you know for sure?
  #5
Old July 19th, 2005, 05:59 PM
yes..it is for your gas reserve tank. lever towards you is main tank away is reserve..want to make sure you running with it towards you in the event you run out you will have 8 gallon reserve left. If you are running in reserve mode..well...when your out your out. :{ Your tank has to lift tubes in it, the gas tank has a tunnel through the middle that the reserve tube picks up from. Scotty
  #6
Old July 19th, 2005, 06:04 PM
The switch runs to a valve underneath the driver seat. Your main fuel line runs to this switch and becomes two separate lines. One pulls from the main tank and once switched to reserve it pulls from the other tube that runs deeper in the tank to pick up the remaining 8 gallons. I have used my reserve a couple times. Could keep from ruining a day on the water very quickly. Good Luck. Scotty
  #7
Old July 21st, 2005, 06:55 AM
hey thanks for the info. thats what i had heard but was not sure. nice to know. see ya later.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
cajun livewell question CAJUN95 Cajun Special Boats 1 April 18th, 2007 12:41 AM
New Boat: Center Console , Walkaround, or Dual Console PAkev Boat Topics and Questions (not engine topics) 17 April 2nd, 2006 08:14 AM
1994 cajun 1850 fishmaster prop vetdoc1 Prop Questions and Topics 11 September 26th, 2005 02:54 PM
Center console FISHERJEEP Boat Restoration and Building 4 June 30th, 2005 11:45 AM
Moulding for 1997 Cajun FishMaster swade28 Boat Restoration and Building 3 June 29th, 2005 05:32 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
