Re: Converting a Johnson 9.9 to a 15 hp
From that very good article above:<br /><br />Difference between the 9.9 & 15hp : When they designed this series of motors, they designed it as a 15 hp & then detuned it with a different carburetor for the 9.9. When the 9.9hp and 15hp came into being in 1974 and up thru 1978, the only real difference between the two motors was the carburetor. In 1979 they added a shim, part #325038, (one for each cylinder), behind the leaf valves & under the stop plate for the 15 hp, apparently to allow the motor to suck more fuel & air mixture in. <br /><br /> <br /><br />The outside visual dimensions of both carburetors appear the same, unless you look inside the throat. If you look in from the rear, you will have to position the throttle plate to a horizontal position to be able to see the throat very well. The 9.9 hp carburetors internal throat is .625 dia., 15 hp internal throat is .875 dia. up until late 1987 when they went to a plastic topped carburetor. The outlet or rear throat dia. is the same on both to match the manifold port dia. The idle jet venturi system is also slightly different between the two. The part number for the the pre 1987 9.9 hp Carburetor Assembly is #388936, while the 15 hp Carburetor Assembly is #338273. This increased dia. & larger main jet allowed it to breather better & pull more fuel in, increasing the RPM about 1000 RPM.
