  #1
Old May 25th, 2001, 06:13 PM
SeaBear SeaBear is offline
Default Mariner 3.5hp choke problem
I have just [yesterday] bought an old Mariner 3.5hp outboard (I believe this is actually a Yamaha?). It was started in a tank when I bought it and run off the choke in and out of gear, etc and seemed great so I paid the man his money. Put it on the back of the dinghy in the evening and it barely would run at all off the choke and either on or off would not rev above mid throttle in gear? I have read other related forum apends and have noted comments relating to jammed floats and dirt because the only other things that happened to it were being laid on its side in the boot and getting a full tank of 50:1 unleaded 94 petrol [2 days old]? it was also at a slight angle [trimmed in] from the transom ... any help would be great? ... SeaBear
  #2
Old May 26th, 2001, 06:41 AM
12Footer's Avatar
12Footer 12Footer is offline
Default Re: Mariner 3.5hp choke problem
I would still suspect the carb,Seabear.The fact that it ran fine before it was laidon it's side, means that something in the float bowl (a piece of debris,water,old fuel)got into the pick up tube,and is now "hanging-out" there.Remove the bowl,and see if there is anything in it.
__________________
"Did you hear about the guy whose whole left side was cut off? He's all
right now."
  #3
Old May 27th, 2001, 05:12 PM
Thanks 12Footer ... I removed the carb and blew [mouth not airline] most of the jets, etc but there is a small brass tube which runs vertically from top to bottom of carb and passes through the throat of the carb? Not seen this before - but the tube didn't want to come out so I didn't force it? Anyway, rebuilt the carb and refitted it also emptied the pipes and tank and used fresh petrol/oil and restarted it - slightly better but still playing up. I guess I should do it again but remove this tube and check it out as it may have an orifice in the tube where it passes through the throat and it may be blocked? Does anyone know if this tube is just a push fit or what?
  #4
Old May 27th, 2001, 06:26 PM
12Footer's Avatar
That brass tube is the pickup tube, and is a prime suspect. It acts like a the tube in one of those lawn sprayers.As water from the hose (air in the case of your carb) flows-over the top, it sucks fertilizer (fuel in the case of your carb) out of the canister (bowl on you carb).They do come out, but can sieze in-place.I have broken them before,so you are right in your caution. I would take it to a garage, and ask them to clean it with compressed air. This doesn't allways work,and in worse case,you WILL have to remove it.Also, note that there is a brass venturi on the side. This is the jet, and if plugged will cause the same thing. It meters the fuel.
__________________
right now."
  #5
Old May 28th, 2001, 06:54 PM
Bingo! I completely stripped the carb and when I removed the little brass tube, etc they were covered in crud. In fact the tube/jet that is the feamle to the long brass tube has about 8 drillings - well 3 of them were completely blocked! Anyway I didn't finish until 7pm so I'm off up the river tomorrow to test it but it ran great in the dustbin!!! Thanks for your help ...
  #6
Old May 29th, 2001, 06:23 PM
OK - I spoke too soon! It started up fine and would sit at a nice idle after about a minute and off the choke! So, after ithad run for a bout 5 minutes I cast off and up the river I went, against the tide so if I did have to row?? Well, it runs for about 15 minutes and then dies and will only restart if left alone for a bout 5-10 mins and then it ran for another 15 mins and died? I have put an inline filter in after cleaning after the carb but there is quite a lot o frust in the tank ... I'm pretty sure the tank breather is OK but does anyone have any other ideas?
  #7
Old May 29th, 2001, 06:58 PM
I was just wondering if a fuel pump can be fitted to this outboard? Partly to improve fule flow in case the inline filter is restricting flow? Also, because I could also use a remote tank ...
  #8
Old May 29th, 2001, 08:51 PM
JB's Avatar
JB JB is offline
Ahoy, SeaBear. Yes, a fuel pump can be fitted but it wouldn't be a "factory" job. I have seen (and done) adaptations of OMC small engine fuel pumps to engines not originally intended for remote tanks. It requires a little machine work to make a mounting plate for the pump, drill and tap the crankcase for a fitting to attach a small tube to provide crankcase pressure/vacuum to the pump, and finding an appropriate spot to actually mount the pump. I ran a Johnson 3 hp with one of these adaptations off a 6 gal tank for several years. Worked marvelously. BUT! if you can't do it yourself it could be very expensive, perhaps prohibitively so.Good luck.JB
__________________
RED SKY at night. . .
JB
  #9
Old May 30th, 2001, 02:23 AM
Ahoy JB! Thanks for info on fuel pump ... do you know what the small rubber pipe is on the side of the crankcase on this engine? It is only 2 inches long and loops out of the crankcase and then goes back in an inch away? I had assumed this may have been for a pump but if not then what is it for?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mariner starter 150 choke lookingforluck Mercury & Mariner Outboards 0 March 6th, 2007 10:03 PM
50 hp Mariner 3 cyl auto choke check ba_50 Mercury & Mariner Outboards 0 February 7th, 2006 03:07 AM
1985 50 hp mariner choke srussell28 Mercury & Mariner Outboards 0 August 6th, 2005 04:27 AM
Mariner 40 have to choke t run wot d67bart Mercury & Mariner Outboards 1 June 28th, 2004 02:31 PM
choke wires 15 mariner 4 stroke outboard1 Mercury & Mariner Outboards 3 November 9th, 2003 07:15 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
