I bought a new Triton T19 with a 200 mercury EFI. I have tried different conbinations with the Jack plate motor tilt and have no luck with the hole shot.I have a 25 pitch 3 blade prop on now.Please help!
I relate these prop gurus up there with rocket scientists, LOL.But I'm an idiot when it comes to props.Try this link. There are a couple real smart prop guru types who can whittle-down a telephone pole,and make a racing prop outta it...Well, maybee not, but they are on the ball ------------------I'm no expert, but I DID sleep at a Holiday Inn last night!
__________________
"Did you hear about the guy whose whole left side was cut off? He's all
right now."
After testing that link, i found it does NOT work. Try this one..........http://www.wmi.org/bassfish/bassboard/Then, click on "other Topics". You'll see "props" there. Sorry bout the merry go-round ------------------I'm no expert, but I DID sleep at a Holiday Inn last night!
__________________
right now."
DO YOU HAVE THE NEW STYLE TEMPEST PULL TWO OF THE PLASTIC PLUGS ON PROP THAT SHOULD FIX THE HOLE SHOT AND WHAT IS ENGINE TURNNING RPM WISE SHOULD BE 5500 TO 5800 THE BEST WAY TO PROP A BOAT IS TEST IT WITH BOAT EMPTY AND PROP IT TO HIGH SIDE OF RPM RANGE.
