kbergman10
- May 2, 2006
- 6
I have a 1968 Evinrude Triumph 55hp motor and had a question about the electric choke wire coming to the key switch. Can this wire be hooked straight to the accessory wire or do I need a ignition with the push to choke feature? The engine has a setting on the back for choke on off or automatic, so if it set to auto and the wire to acc. would that be correct?
