Re: Johnson 5.5 Seahorse CD-16 cooling problem
First, I sure appreciate all this advise. I have removed the engine and have inspected the impeller and housing. It looks perfect and quite new (???). But, I think I see the problem. When I took engine apart from the lower end, a few pieces of hard black plastic fell out. I fit it together, sort of, and it is (was) about 3/8" deep, inside diameter about 3/8", outside about 5/8+. It appears to be a collar and looks like it would fit on the copper line that goes from the impeller upwards. It makes sense that if the copper line wobbled around without the support of the collar, under fast throttle, it would force water up and through...but on idle or slow, if it was not aligned properly (with the help of a collar ??), it would not get enough water directed up the hole. I have ordered a manual and hope it has a schematic so I can see the parts and how it fits. Also to id any gaskets or seals I need to put it all back together. Unless someone has anything to support or add, I'll wait for the manual. Thanks, Bob
