I have just bought a 1981 Evinrude 4.5 Long shaft. It is E5RLC1C which based on information on this and other sites tells me the year and that the long shaft is it's original configuration.<br /><br />This is a little more complex than my existing suzuki DT4 and I have a few questions, would appreciate your humoring and assisting me. I will try to be complete :<br /><br />What is the starting procedure ?<br /><br />1. No fuel shut off valve ? did I just miss it or is it always on ? (onboard tank which I assume is gravity fed)<br /><br />2. Whats with the funky choke and which position should it be in for starting and should I be looking for it doing something specific under the hood when I twiddle it to check that it is working ?<br /><br />3. What's with the lean / rich knob - how should it be set for starting ?<br /><br /><br />So basically I think I should set the choke and pull firmly on the rope like I do with Suzie - but it doesn't seem to pull smoothly, there is a metal doo-hicky attached to where the starter rope goes round (on a horizontal axis) that seems to want to jump up and engage with the flywheel (both have mathing teeth), but it seems a little floppy/sloppy right now and needs to jump maybe an inch (and does) - it just doesn't seem right - is this normal (I am thinking not). Also there is no natural recoill or draw to pull the rope back in. Again, I'm thinking this is not normal.<br /><br />The motor appears to turn over nicely and from what I can tell is not seized in any way.<br /><br />I do appear to have a clean carb, fuel lines, tank, fresh 50:1 fule etc and good plugs - though I am not sure how to check for a spark without being able to turn the motor over.<br /><br />I can upload photos if needed but you all seem to know this stuff in your sleep so my guess is you'll say- "oh yeah thats the gizzmo that didn't ........ and you just need to do this".<br /><br />I am based in Metro West Boston and boat in Rhode Island (upper Narragansett bay)<br /><br />Thanks<br /><br />Mark
