I have an intermittent problem with my tilt/trim. Sometimes the motor will go up but not down, sometimes it will go down but not up and other times it works fine. It doesn't matter if I use the button on the gear shift lever or the buttons on the engine cowling I get the same results. When it is acting up I can usually play around plugging and unplugging the blue and green wires that run from the switch on the cowling and eventually get it to work but I am afraid someday I may get stuck with my engine tilted. Does anybody know a logical procedure for trouble shooting this problem?
