Re: 77 johnson 85hp Fuel bulb collapses
So everything from the linkage to shift rod , works correctly.<br /><br /> If your linkage etc. is like I think it is , theres not much to it.<br /> <br /><br /> With shift cable unhooked from linkage to shift rod.<br /> <br /><br /> Have someone move shifter through gears F - N - R . <br /><br /> <br /> See if the rod at the end of the cylinder , moves correctly, as the shifter is moved. If it does, then something is not hooked up correctly, at the linkage. <br /><br /> Though I dont know what , or how its wrong...<br /><br /> Its not really difficult, to figure out, but its difficult, for me to explain .<br /><br /> All thats left , is the shifter and cable, or its, improperly installed/ connected.<br /><br /> At least you know, the lower unit is shifting correctly. <br /><br /> You did check, by rotating prop when in gear right? <br /><br /> You may also have the shift cable adjusted wrong .<br /><br /> I assumed , that it was working fine, and suddenly, its not.<br /><br /> Try to explain, what you have done, and checked . All I can do is guess .<br /><br /> There's , like I said, not much to the shifter, to shift cable, to linkage. <br /><br /> You really should, be able to figure it out. <br /><br /> You have a manual right??<br /><br /> If you do, and you can't figure it out . <br /><br /> You may want to ask someone , with more experience, to look at it for you. <br /><br /> I'll still try to help , if I can.<br /> <br /> Good _ Luck,<br /> <br /><br /> KYHunter
