I have an early 1980's model Mariner 40HP outboard and every time I pump the gas bulb, gas pours out of a hole on the top left of the carburetor.(This is the bottom carburetor) After I crank it, the gas pours out of the same hole non stop. I had both carbs rebuilt last year. The kits were $130.00 a piece & labor was $65.00 per carb. I wonder if the float might be stuck, would this make this happen? Or if maybe they did not correctly put the valve seat back in. If anyone has information about what could be causing this please let me know.
Thank you, Wilson
Wilson
