Hello everyone, I just bought a 97' Johnson 9.9 that was used as a backup motor in saltwater. Took it out today on my 10' Avon Inflatable and it ran perfect for about 10-20 minutes, then stopped. Tried to restart it and would only start with the choke pulled out, then if I pushed it back in and gave it throttle, it died. If I left it with the choke out it would run up to about 10% power. Turned it off for about 30 minutes and it started running like new again for about 20 minutes, and then the same problem. Could it be that the thermostat closes the fuel flow into the engine if it's overheating? Didn't seem too hot to me. I'll order a new water pump kit and try that. Is there anything that indicates if water pump is working fine in these engines? By the way, in all this time, the motor always started on 1st pull.<br />Thanks in advance for any help!
