I have some questions on removing the water pump.<br />I apreciate everyones help in isoalting the problem. I am just in the planning stages so I want to make sure I understand the steps.<br /><br />As ezeke mentioned these are the general steps to remove the water pump. I have a few questions below<br /><br />Step 1 - remove shift cable<br /><br />Step 2 - remove four bolts from under cavitation plate and one from above and below trim tab. Saw four not seven ezeke.<br /><br />Step 3- Remove gear case<br /><br />Step 4 - Remove water pump and install new one<br />Inspect gear case<br /><br />Question on step 1 . Observed it's below carb. Tight space. How do you remove the tiny bolt,its very small, how is it held in).It look like two metal arms holding a rod with a pin or bolt in it. This obviously controls the forward and reverse direction and speed.<br /><br />Doesn't the cable with the swivel top get pulled through when you remove the gear and when you reinstall the cable it is pushed back up.<br /><br /><br />All else make sense.
