hi, i own a 25 hp johnson motor about 1974. this motor has been modified with parts of 1970 model (low tension and high tension coil are the same one). I have no electrical output on the motor. ther e is an external power outlet on motor side with yellow lead. this lead has been cut. As someone an idiee to connect electrical accessories on the motor.<br />thanks
