  #1
Old January 26th, 2002, 01:25 PM
MURX MURX is offline
Default MERCURY OIL TANK
After having my boat inspected and serviced I ran it and had the low oil alarm go off a few times while running on smooth flat water, when I got home I called my dealer and he said after a boat sits for long periods as this one did, the oil has a tendancy to gel up, he suggested I inspect the screen on the pick up in the oil tank which I have done, he said to clean it with carb cleaner and run it again, the main resivoir was half full during the shakedown and the small resivoir on the engine was about 3/4's full, anyway I decided to drain the resivoir and clean it out found a lot of jelly on the bottom of the tank, I rinsed it all out with pre mix and now I'm ready to re-install the tank is there a method for priming the system? or does the crankcase pressure immediately prime the system? this is '91 merc 175 thanx in advance guys, Don
  #2
Old January 26th, 2002, 01:45 PM
johnkc johnkc is offline
Default Re: MERCURY OIL TANK
murx, you have to mix the fuel inthe tank 50:1 first off. then fill the oil tank , then fill the tank on the engine.then start the engine on the 50:1 gas mix, let it run ,while running you have to bleed the oil pump, a small phillips screw on the pump, allow plenty of oil to purge out of bleed screw.you may loosen the cap on the motor and let it over flow allowing the air in the line from the remote tank to purge,this does get messy though. then run the full tank of 50:1 mixed gas out .then verify that the remote oil tank has consumed oil before switching back to straight fuel.it will smoke alot with the doubled up oil ,just don't idle too much and you shouldn'thave a problem fouling plugs.good luck
  #3
Old January 26th, 2002, 06:10 PM
Hey John, I do have an extra six gallon remote tank around here somewhere that I can use so that won't be problem, I quess I'll pull the engine mounted tank off too and clean it out as well, thanx again Don
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury Model 3.0 Fuel Tank DTS1290 Mercury & Mariner Outboards 0 June 12th, 2006 09:18 PM
90 HP Mercury Oil, mix in gas or separate tank? lmccollum4 Mercury & Mariner Outboards 10 August 11th, 2004 06:24 PM
Fuel tank parts, old Mercury vacuum-type remote tank John Reynolds Mercury & Mariner Outboards 3 April 8th, 2003 12:34 PM
84 Mercury gas tank Wide_One Mercury & Mariner Outboards 9 March 18th, 2003 07:25 AM
Mercury Gas Tank Petrajn Mercury & Mariner Outboards 1 July 15th, 2001 03:22 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
