  #1
Old January 25th, 2002, 12:25 AM
Rusta Rusta is offline
Default 1978 70hp Mercury Powerhead
I have recently discovered a hole below No3 cylinder on my powerhead. I have been told that this can be repaired by means of welding. Can anyone advise as to whether this is a satifactory way of dealing with the problem. Welding is to be done by certified engineers. Any advice is greatly appreciated.Thanks from Down Under
  #2
Old January 25th, 2002, 05:22 AM
petryshyn petryshyn is offline
Default Re: 1978 70hp Mercury Powerhead
>where exactly is the hole located?>what caused the hole to begin with (froze up, porous casting etc.)?>is it in the cylinder wall?
__________________
Alias "schematic"
  #3
Old January 25th, 2002, 06:03 PM
Thank you for your quick response. The hole is located in a small hollow approximately an inch down from the spark plug. This hole is the size of a match head (roughly). The hole is not in the side of the cylinder. I have beeen informed that it is electrolysis that has caused the problem. Apart from the small(??) hole that is present the rest of the unit is in A1 condition.Thanks again for your helpGarry
  #4
Old January 25th, 2002, 07:25 PM
I wouldn't hesitate to weld it in that area, especially to save the motor. . .
__________________
Alias "schematic"
  #5
Old January 25th, 2002, 07:26 PM
alcan alcan is offline
Hello Rusta The hole you describe is in the water jacket cover. If you remove it, a good tig welder could fix it. Did you look into the cost of replacing this cover? You might be able to find a good used one. Let us know how you make out. Good luck.
  #6
Old January 25th, 2002, 07:47 PM
Schematic & AlcanThank you for the positive notes you have sent back to me. I dont know how long the weld will last but to replace the power head for that particular motor was in excess of $AU3,000.00. Considering that I paid 3,000 for the boat,motor and trailer a couple of hundred dollars is a meer drop in the ocean.I will let you know of the outcome.Thanks againGarryHOBART,TASMANIA,AUSTRALIA
  #7
Old January 25th, 2002, 07:56 PM
I took it that the hole was in the combustion chamber end of the cylinder. Heck, if its in the water jacket cover, I'd weld it at home! How long will the weld last you ask..... It'll outlast the engine if done right. Just be sure to resurface the gasket face and check for straightness before installing. As alcan says, should be easy to find a used cover around. Go the cheapest route.good luck!
__________________
Alias "schematic"
  #8
Old January 25th, 2002, 09:09 PM
schematicYou are quite correct, The hole is in the combustion chamber end of the cylinder ,with my limited knowledge of outboard motors I have obviously confused Alcan, SORRYI hope you are still right about the welding anyway.Many thanks for all of prompt replies.Garry
  #9
Old January 26th, 2002, 07:09 AM
Hi Rusta Thanks for clearing me up on your hole. But the answer is still yes. There are people that are as skilled as brain surgens with welding. The right person will cure your problem. Good luck.
  #10
Old January 26th, 2002, 07:57 AM
Ditto alcanbut be careful on the brain-surgeon welder thing.....LOL There could be some sensitive_____out there.
__________________
Alias "schematic"
  #11
Old January 26th, 2002, 11:16 AM
Hooty Hooty is offline
Shucks gang, I'ed fix that with J-B Weld.c/6hooty
  #12
Old January 26th, 2002, 01:59 PM
Thanks for all of your extremely prompt and positive replies guys. It would be a pity to lose the old girl as it really pushes a 14ft runabout along at a great rate of knots. I will keep you posted on the outcome.Thanks againGarry
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
info for my 1978 70hp Mercury texas_james Mercury & Mariner Outboards 5 July 26th, 2009 01:51 PM
Spark plugs 1978 mercury thunderbolt 70hp AJ in NH Mercury & Mariner Outboards 1 June 30th, 2006 01:10 AM
1978 Mercury 700 - 3 Cyl. 70HP - great idle but no acceleration morsanutto Mercury & Mariner Outboards 7 September 4th, 2005 01:48 PM
1978 Mercury Powerhead Problem joseph14 Mercury & Mariner Outboards 2 April 3rd, 2004 05:15 PM
1978 mercury 70hp starting problem white mach1 Mercury & Mariner Outboards 2 July 19th, 2001 08:06 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
