  #1
Old February 16th, 2002, 06:50 PM
alvin alvin is offline
Default mercury 115 low compression one cylinder - HELP
Just bought an '86 mercury 115hp. Wasn't running when I bought it ("just needs a new control box - everything else is perfect")Post-purchase examination of the engine revealed a cylinder with a botched helicoil job and a nonfunctional spark plug. I retapped the plug hole for an 18mm spark plug and fired it up today. It starts almost instantly when warm but runs a little rough. The cylinder in question seemed weak - didn't seem to matter very much if the plug wire was connected or not. With the plug out and the waterjacket cover removed, I did my 'compression test': with the piston fairly close to the plug end of the cylinder, I put MY MOUTH over the plug hole and blew into the cylinder, holding pressure in the cylinder. I could definitely feel the pressure in the cylinder going down. I repeated this on one of the other cylinders and it definitely felt like the pressure was holding - a noticeable difference.Here are the questions: How do I determine what the cause of the cylinder leakage is? Visual inspection of the top of the piston and the cylinder walls looks good (some carbon on the piston but no holes anywhere). Could the rings possibly be stuck from the cylinder being dead (for who knows how long)? I have a can of stuff called Power Tune. Can I use this to try to unstick the rings? Instructions for this stuff call for running the engine at full throttle for 5 minutes after a hot soak.Any harm in running the engine with a weak cylinder? Whats the fix if the decarb doesn't work?
  #2
Old February 16th, 2002, 09:08 PM
Fouled Plug Fouled Plug is offline
Ensign
Default Re: mercury 115 low compression one cylinder - HELP
Oral compression test? Haven't heard of that since Clinton was in office. Beg, borrow, or steal a compression gauge and get a reading of all cylinders first. I wouldn't say your motor has been given the "kiss of death" until we see some solid data.
  #3
Old February 16th, 2002, 09:16 PM
62_Kiwi 62_Kiwi is offline
LOL Good one Fouled Plug!
  #4
Old February 17th, 2002, 11:21 AM
12Footer's Avatar
12Footer 12Footer is offline
LOL. Yea, all is not lost. It could be stuck rings or blown head gasket or something..U really need a gauge,or it will just depend on what your definition of "compression" is.Sorry,had to add to this somehow.
__________________
"Did you hear about the guy whose whole left side was cut off? He's all
right now."
  #5
Old February 17th, 2002, 12:04 PM
evin300 evin300 is offline
remember not rev the engine at full throttle, unless it is on a boat.
  #6
Old February 17th, 2002, 01:31 PM
Thanks for all the input so far. Will try to get compression numbers in a day or two.
  #7
Old February 17th, 2002, 03:38 PM
ajohnston ajohnston is offline
Had somewhat same problem and it was a blown head gasket. check plugs for water
  #8
Old February 18th, 2002, 03:06 PM
Here's some 'real' compression data (taken with engine warm): 130, 125, 85, 125, 130, 130. A shot of 2-stroke oil in the low cylinder took the reading up to 115. What's the verdict? What's the fix (if any)?
  #9
Old February 18th, 2002, 04:11 PM
Ensign
Decarb the low cylinder first as a long shot. It may not help, but it's certainly worth a try. Could be scored cylinder walls, or bad rings. Maybe you'll get lucky and they're just stuck, though. Good luck!
  #10
Old February 18th, 2002, 04:44 PM
As you're well aware, I'm kind of new to outboard motors. Could you outline a recommended 'decarb' procedure for me? Thanks a bunch!
  #11
Old February 18th, 2002, 06:23 PM
Hooty Hooty is offline
Hey alvin,Not sure who's idea this was, maybe Schematic's, but tilt the engine up so's the cylinders are vertical. Remove spark plug and dump the de-carb in the low cylinder and let it set for a day or so, empty the stuff and follow de-card instructions. Keep us posted.c/6Hooty
  #12
Old February 25th, 2002, 06:46 PM
Did the decarb. Took the motor out to the river to run the decarb stuff out. Motor seemed to be running a lot smoother. Ran it up the river about 2 miles - ran great. Then it cut off with kind of a clattering sound. I was able to get it restarted but it runs rough and clatters. We limped back to the dock. I pulled the plug out of the repaired cylinder and found aluminum deposits on it. When I first got the motor and pulled that plug I found the same stuff on the plug but figured it was some kind of 'liquid aluminum' stuff since the plug hole had a bad helicoil. Now I know why the helicoil was bad. Now I know why the hole was helicoiled in the first place - aluminum deposits! Hey Fouled Plug, I noticed in one of your other posts that you asked someone if there were aluminum deposits on the spark plug. What is this a sign of (other than major problems)?I've rebuilt a couple car engines and dirt bike engines. Is dissassembly/reassembly of this motor possible for the home mechanic or are there a lot of special tool required? Is sleeving the bad cylinder a realistic fix for this motor?
  #13
Old February 27th, 2002, 02:54 AM
Valv Valv is offline
Alvin,I believe at this point you will have to rebuld motor, and/or if you are lucky just new pistons, rings, and cylinder hone. You will need ring compressors, which are very expensive or have somebody with them lend them to you. It's a 6 inline, and I've been there too, you won't put the pistons back in unless you compress rings. I spent 2 days broke 2 sets of rings (that means ca. 30 rings) and finally gave up and toke it to a shop.I have a nice powerhead from a 1350 6 inline here, if you are interested I'll let you have it for just few bucks, but it costs a fortune to ship.Val
  #14
Old February 27th, 2002, 10:58 AM
On second thought, my powerhead won't work, this one has 3 side fuel pumps on starter side, yours has only one on throttle lever side.Sorry.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
no compression in 1 cylinder jayvaughn Force & Chrysler Outboards 8 November 20th, 2003 07:07 PM
'92 135HP Mercury - no compression in one cylinder TimS Mercury & Mariner Outboards 14 July 24th, 2003 03:51 PM
Mercury 115 low compression top cylinder medic28640 Mercury & Mariner Outboards 1 June 14th, 2003 11:21 PM
no compression on 3rd cylinder wilntam Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 April 15th, 2003 10:04 AM
89' Mercury 115. #3 cylinder no compression.HELP 2738 Mercury & Mariner Outboards 6 March 3rd, 2003 02:50 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
