Hello to all outboard gurus! <br />You have never failed me yet, so here goes.<br />I am interested in a '64 Arkasas Traveler fiberglass boat with the following motor. I have several questions?<br /><br />(1) I can't find the model serial number on what looks to be a 77 johnson 25hp. Could not find it on the transom bracket, where else is it found?<br /><br />(2) Motor has 100 top and 100 bottom compression and looks to be in decent condition. Starts right away and idles pretty good on muffs. Throttle cable is attached but shift cable is not and looks real worn. Is that very hard to replace? Controls are OMC and look to be in the same vintage as motor.<br /><br />(3) The boat is 14 foot and weighs somewhere in the 200-250# range. What kind of speed could i expect from the boat/motor with a 6 gal tank and 200 pounds of me in it. I know there are alot of variables but I'm looking for a good educated guess.<br /><br />Thank you,<br />Jim
