Sometimes during start-up, motor will start and immediately go to 3000 rpm, then not drop down to normal idle rpm. If I turn it off, then re-start, it will then run around 700-800 rpm. This problem also occurrs when pulling back on the throttle and going back into neutral, where the rpms will jump back up again. It appears that the throttle linkage is working fine when I remove the cover and check it. <br /><br />Any ideas on what to look for next? Could old spark plugs be causing the problem? Kind of at a loss on this one.<br /><br />Thanks for any suggestions on what to check.
