1) I went and checked out the boat today. It seems that my friend's dad put the motor in the upright position sometime in the past few months. When I looked around the gear case, I noticed some greasy/oily looking stuff on the backside (opposite side of the propeller). It is up on the top of the gear case, the little ledge there. I am guessing the seal or gasket right there may be bad? There is no fluid on the floor and there is only about 1/2-1 teaspoon of fluid bulit up there. <br /><br />What could be the cause of this?<br /><br />If this is bad, how hard is it to change that seal and/or gasket? Easy enough for a semi-handy guy? <br /><br />What if I put on the muffs and start it up to see if it leaks any, could that hurt the motor? <br /><br />2) If I can't change it, how much would someone charge me to change it do you think?<br /><br />3) How much are general tune-up on these motors?<br /><br />I am going to go look at it tomorrow again and see if I can make sure that's where it is coming from.
