  #1
Old August 27th, 2001, 05:59 PM
nick23 nick23 is offline
Default 1984 50 hp mercury doesn't spit water out pee hole
I have a 1984 50 hp mercury that doesn't spit water out of the pee hole but it comes out the exhaust. I replaced the impellor and it still didn't spit water out the pee hole. I also found out that the pee hole was plugged with mud, I unplugged it and still it wouldn't spit out any water. Instead I can feel warm air blowing out of the pee hole now that its unplugged. I was told to check and see if I had a plugged or bad thermostat but I can't find the thermostat. Do I have a thermostat and if so where is it? What does it look like. If there is nothing wrong with the thermostat then why else could it not be pumping water? Also why is there warm air coming out of the pee hole? Any help would be appreciated. thanks Nick.
  #2
Old August 27th, 2001, 06:19 PM
kev_79 kev_79 is offline
Default Re: 1984 50 hp mercury doesn't spit water out pee hole
Thermostat housing is in the "head" of the motor. The head is the part on the powerhead that is farthest to the back. It is where the spark plugs are. Look there for some type of bulge, or place where there are bolts that don't go around the "head". If ya can't find it, write back, we'll find it eventuallyAlso, the thermostat, when you get to it, will look kinda like Saturn, or something to that effect, if you don't know what you are looking for. Good luck, let us know how it goes.
  #3
Old August 27th, 2001, 06:47 PM
Down South Down South is offline
Are you sure you have that pee hole unplugged. If you have water coming out the exhaust I would think it should be coming out the pee hole too. Pull the line loose from the engine that feeds the pee hole. sometimes trash will get trapped at that spot. Put the muffs on it or put it in the water and crank it after you have that line disconnected. Crank it up and take a soft piece of wire and see if you can clean out the fitting that the hose hooked to. I bet it will start peeing again.
  #4
Old August 28th, 2001, 08:25 AM
pipestone guy pipestone guy is offline
Hey Nick,Had the similar problem on my old 'rude. Fixed mine back taking the head gasket off and the head gasket cover and cleaning all the crud out. Works like a charm now.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury 1985 9.8 wont spit water in neutral shaydaniel Mercury & Mariner Outboards 2 February 17th, 2007 10:19 AM
Motor won't spit out water jrcrote Johnson & Evinrude Outboards 3 July 7th, 2006 03:35 PM
Won't spit Water? tiller7104 Force & Chrysler Outboards 7 April 1st, 2006 04:28 PM
why do large boats always spit out water? massimofinance Boat Topics and Questions (not engine topics) 14 June 9th, 2005 09:33 AM
140 Evinrude doesn't spit water Krazykjh7680 Johnson & Evinrude Outboards 9 March 19th, 2005 05:17 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
