Re: OMC Fuel Connecter O Ring Replacement
It's easy...(yeah...famous last words)....<br /><br />Take a stiff piece of small wire and bend a little hook in the end. The stiffer the wire the better.<br /><br />Take a blunt tool like a small punch and push the connectors ball down and then with the hook wire, reach in and grab the old oring and pull it out. Make sure you get it all out.<br /><br />Lube a new oring and just push it in place.<br /><br />Like anything else, sometimes this goes easy....sometimes you can fool around for 10 minutes picking the old oring out.<br /><br />EDIT: Forgot to add...if you lightly hold the connector in a vise so you can use both hands does help.
