  #1
Old December 29th, 2001, 12:45 PM
GOOSER GOOSER is offline
Default LOW COMPRESSION/1989 MERCURY
I AM CONSIDERING THE PURCHASE OF AN 80 HP MERC 1989 VINTAGE. CURRENTLY IT CARRIES 90 LBS COMPRESSION IN CYL 1 & 3. BUT ONLY 60 LBS IN CYL 2. MECH WANTS TO HONE & RERING ALL 3. ALSO NEEDS A STATOR AND CARB REBUILD. MECH THINKS SINCE IT SAT FOR 3 YEARS THERE IS RUST ON CYL WALLS. ANYTHING ELSE NEED TO BE CHECKED BEFORE I COMMIT TO BUYING IT???
  #2
Old December 29th, 2001, 12:50 PM
Fouled Plug Fouled Plug is offline
Ensign
Default Re: LOW COMPRESSION/1989 MERCURY
Was the test done with the motor warmed up? If so, I'd give a decarb treatment a try before tearing it apart. Sitting will cause the piston rings to stick sometimes. I'd also check the lower unit lube, look for water and/or metal shavings.
  #3
Old December 29th, 2001, 01:17 PM
THE ENGINE WAS NOT WARMED AND ALL PLUGS WERE REMOVED DURING THE ENTIRE TEST. ALSO NO ADDITIVES WERE USED...
  #4
Old December 29th, 2001, 01:36 PM
Rex Rex is offline
if them want 1500 for it then take offfor what the repair would be.I would say buy it and run it for a little bit. and i bet you will be happy with it.but do not pay them what they want.I'm talking about a very good price to take that chance.good luckRex a. Hubble
  #5
Old December 29th, 2001, 03:29 PM
alcan alcan is offline
Gooser,I would check everything.From the prop to the starter rope,from the gas cap to the end of the exhaust pipe.This is an expencive habit (I mean hoby)From Your description this motor dosn't sound like it has alot going for it.Did you want a winter project? If your mechanicly inclined, wanna spend a few bucks it might work out. Good luck.
  #6
Old December 29th, 2001, 03:43 PM
Ensign
Has this motor run at all? It may be as simple as cleaning the carb and firing it up to see what you really are looking at. Do not rely on cold compression readings, especially since the motor sat for 3 years. If it has not run since, it is premature for a mechanic to be talking rebuild. If you can get it running, check the hot compression. If not, your wallet may take a real beating on this one. Best to look for a good running used motor before buying a dead one.
  #7
Old December 29th, 2001, 04:04 PM
ASKING PRICE WAS ONLY 750.00 WITH A STAINLESS PROP THAT NEEDS A HUB. THE MOTOR RAN FINE(I KNOW THE OWNER) UNTIL THE STATOR WENT BAD AND HE PARKED IT. SEEMS HIS WIFE GOT THE BOAT AND HE GOT THE MOTOR IN THE DIVORCE!!!
  #8
Old December 29th, 2001, 04:29 PM
  #9
Old December 29th, 2001, 06:58 PM
ODDD1 ODDD1 is offline
Gooser, the last 90 hp merc [1989] i bought damaged Ipaid $250 US for it...and it had a bad cylinder.....there has been some question on this board about proper procedure on a compression test, personally I do them cold and dry...a leak is a leak, hot or cold....if you are seeing numbers under 100 psi the motor is weak....if you got one down 30 from that, its a dead hole, no arguement...
  #10
Old December 30th, 2001, 07:30 AM
GOT 2ND AND 3RD OPINION FROM OTHER MECHANICS AND THEY ALL AGREED THAT IT SHOULD BE RUN TO SEE IF THE (RING) LOOSENED UP AND COMPRESSION WENT UP. ALSO RECOMMENDED SEAFOAM IN THE CYLINDERS TO CLEAN THEM UP. ANY IDEAS ABOUT WHETHER THE CRANK MAY PIT OR DO THEY USUALLY REMAIN IN GOOD SHAPE FROM STORAGE?
  #11
Old December 30th, 2001, 10:11 AM
Ensign
The condition of the crank? Depends on if the motor was fogged for storage, the environment it was in, etc. I would run it on a break in mix of 25:1 for the initial start-up, at any rate. Not that it would help if the crank was pitted, but it should be nicer to the other parts! Good luck!
  #12
Old January 3rd, 2002, 12:02 PM
GLAD I LISTENED TO ALL OF YOU SEASONED VETERANS. ANOTHER MECH AND I BROUGHT IT INTO HIS SHOP AND REMOVED THE INSPECTION COVER ON THE LEFT SIDE. THERE WAS ICE IN THE WATER JACKETS AND AS THE FLYWHEEL WAS TURNED BY HAND WATER WOULD COME OUT FROM AROUND THE BOTTOM PISTON. DON'T KNOW IF THE BLOCK WAS CRACKED OR IF THE CRANK/BEARINGS GOT RUINED BUT I WILL AVOID IT. WILL BE LOOKING FOR ANOTHER OLD ENGINE. MAY HAVE FOUND A NICE 85 EVINRUDE 70HP. ON A BOAT. I FIGURE I CAN SELL BOAT & TRAILER KEEP MOTOR AS IT RUNS VERY WELL AND WAS JUST SERVICED BY MY FRIEND...THANKS FOR SAVING ME A LOT OF MONEY...GOOSER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1989 225 compression johnnyvv2003 Johnson & Evinrude Outboards 9 November 27th, 2005 05:56 AM
1989 Johnson Compression GWMASON Johnson & Evinrude Outboards 5 August 28th, 2004 12:31 PM
1989 evinrude 110 vro compression buzo Johnson & Evinrude Outboards 1 July 4th, 2004 06:19 PM
What should compression be 1989 Yamaha 200 hp?? bowhuntrrl Yamaha & Suzuki Outboards 2 March 30th, 2003 03:43 AM
1989 Johnson 200 hp compression Extra 260 Johnson & Evinrude Outboards 3 January 15th, 2003 03:00 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
